跳转到主内容
加入维修社区 - 创建账户
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Mac's Kernel panic at some apps
Since upgrading to Sierra, my mac has kernel panics at some apps like Microsoft Powerpoint, games or when playing a video. I downgraded back to snow leopard, but it still has the panics.
Here is content of one of my panic reports taking from Snow Leopard logs:
Interval Since Last Panic Report: 191 sec
Panics Since Last Report: 1
Anonymous UUID: 1BB80606-BBC0-4FAE-A75C-A69DE63ED822
Sat Nov 11 13:57:34 2017
panic(cpu 2 caller 0x5bf51c97): NVRM[0/1:0:0]: Read Error 0x00000100: CFG 0x0a2910de 0x00100000 0x00000000, BAR0 0xd2000000 0x7f0c4000 0x0a5480a2, D0, P2/4
Backtrace (CPU 2), Frame : Return Address (4 potential args on stack)
Panic Report
Is it a RAM related problem? I swapped the RAMs with a another pair of RAMs, but it did not help. I still have the crash. I have started the extended Apple Hardware Test, but so far it has not found any hardware issues. I'll report back if it comes across a hardware malfunctioning.
Any ideas will be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
For anyone who has the same problem and likes a quick makeshift solution, though clearly not the best one, visit the following site and download the app. It works!
https://github.com/julian-poidevin/MBPMi...
完成的
添加一条评论
2个答案
已选择的解决方案
I had this exact same problem with my mid-2010 Macbook Pro, for me it was caused by a capacitor on the logic board that had broken and shorted. I replaced mine a couple of days ago and haven't had the problem again since. If you have also noticed that you have a lower than normal battery life then this is most likely the cause. I think it is supposed to be using in powering your GPU's RAM which would make sense why it says that ram is a problem. Until I fixed this problem I used a program called gfxCardStatus (https://gfx.io/) which allows you to force the use of intergrated graphics in a little drop down in the top right of your screen. It will mean that you can't really game with your laptop but it should stop kernel panics.
这个答案有帮助吗?
得分 1
5条评论:
Thanks for replying. Did you replace the capacitor yourself? Could you let me know which capacitor?
Do you mean the one circled in the following picture:
https://camo.githubusercontent.com/53c80...
Thanks.
完成的
So very sorry that I forgot to reply. I did replace the capacitor by myself and yes it is the one circled.
完成的
Does it need high-tech tools for doing so? It must be very tiny.
完成的
I managed to do this myself with a soldering iron that I already had and some fine soldering tips. If you are going to do this yourself; make sure that you put the capacitor on the correct way and watching this video should help with any other questions you may have:
https://www.youtube.com/watch?v=DzcgT_fi...
If you need anything else please feel free to ask, also below is a link to buy the capacitor if you do decide to do it yourself.
https://www.mouser.co.uk/ProductDetail/P...
完成的
Thank you so much for your help, but at the moment the software solution I mentioned in my comment above does the trick. Maybe I'll try the harder alternative if absolutely have to.
完成的
添加一条评论
Kernel panicks could be many things.
Bad RAM or ICs are a last resort and very rarely the issue.
To start, I would try checking the hard drive.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your answer. But I am sure the capacitor mentioned in the above post is the problem. Fortunately, there is a makeshift software solution for this problem:
完成的
添加一条评论
添加你的答案
Saeed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 39
总计 2,312
