跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Bad - no celluar coverage
Okay so have this iPhone 6 with little till absolutely none celluar.. I have looked into it, there is not any physical damage to either wifi/gps antenna, or celluar antenna that i can see, nor on the connections, but i went ahead and ordered the new wifi antenna and celluar antenna.
but is there a way i could check if the IC chips are bad or something?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try Dialing *#06#, do you get your IMEI? Also, look in settings and see if your IMEI is listed there and also Modem Version. there are a few IC chips on the logic board that can lose connection, have bad traces (Pads) or just be in need of replacing.
Knowing if *#06# brings up IMEI and if IMEI and Modem are listed in settings can help know if you are experiencing a chip problem, software issue or just a antenna issue.
The Charging port has your "Data" antenna and your upper antenna is for your Wifi/Bluetooth/GPS
这个答案有帮助吗?
得分 1
添加一条评论
Be sure you have all the updates installed for the system and do a factory reset just to check that it isn't a software issue. If it isn't software related, possibly the parts that deals with the cellular side has gone bad. The wires is a good idea to see if they haven't gone but they aren't usually the common reason. Still worth a shot.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Petter Berget 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 81
