跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
Stuck in reboot loop
Hi guys, thanks for reading my question!
I've got an iPad Air in a reboot loop. It goes to Apple logo, sometimes flashes red, then restarts.
I've tried freezing it then charging it, it charged a little, but still went back into this loop.
Some background. This iPad wasn't charging, so I cleaned the charge port. I then noticed that the battery screw wasn't done up properly. After a half turn the device started pulling a current.
The data is important and I don't want to lose it.
Also, please post educated responses. If you haven't worked on iPads please choose another question, thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Did this reboot loop occur following some physical impact or contact with water or did it just happen out of the blue? Was this iPad previously repaired?
You said after cleaning the port and tightening the screw that the battery was pulling current. Is that because you have it connected to a USB ammeter? If so, what current was it pulling?
Sorry for all the questions but the more info you share, the more directed my answer.
It is entirely possible that the battery is just dead or dying and not charging properly. It could be a defective charge port (check the internal pins under magnification) or it could be a defective charge circuit (caused when using cheapo chargers and cables) .
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the response. I replaced the screen on this iPad. Unfortunately didn't screw the battery screw in tight enough. I got it back and the charging was a bit sporatic on the USB Ammeter.
I eventually realised the problem, however now its stuck in this loop, even though its drawing a decent current.
完成的
I suspect the variations in charging amperage when the battery wasn't screwed in has fried the charging circuit. That's a complete guess. I did try another battery.
To answer your question about how much current it pulls, it pulls 89ma. I know that's probably less than you would expect however the charge port has a few damaged pins.
完成的
添加一条评论
添加你的答案
Aaron Moffatt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 3,692
