itunes reoccuring restore problem
have an iphone 5c im having an issue with, its stuck on restore mode and everytime i try to restore it it goes through everything then goes straight back to recovery mode. have tried flashing it through 3utools flash completed but went back to recovery
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论:
@refectio do you have any ideas please
完成的
What was the original issue? If you let it continue, does iTunes give you an error message? My concern here is that you have an Error 4013 condition.
完成的
its give 4013 a few months ago when i tried it but not this time, just error 2009 which it stopped giving when i disconnected the battery and plugged into the bench supply
完成的
top liquid indicator is red aswell
完成的
Well, that changes everything... Did you do a full decontamination?
完成的
显示更多的1条评论
添加一条评论
