跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
My iPhone lost it's sound?
My iPhone 3Gs has lost all sound! I am jailbroken on bb 6.15 and i can't take it in to apple! The sound comes back every once in awhile, but then it just starts to static and just completely goes out! Nothing sound related works.. not even when I put headphones in. Ive tried restoring and re-jailbreaking, but still the same thing! Is it something that I can fix or replace myself for this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Apple just released an iOS update with "security" features which are rumored to make jailbreaking more difficult.
完成的
添加一条评论
2个答案
最有帮助的答案
Was it working before you jailbroke it? Has it had some kind of catastrophic physical event happened to it (ie dropped)? If it was working before you jailbroke it and it stopped working afterwards I would say that it's a software problem and you should try restoring it (unjailbreaking it).
这个答案有帮助吗?
得分 1
添加一条评论
Sry about that
这个答案有帮助吗?
得分 0
1条评论:
structure412, your question shows as an answer. if you need some help with that, click on the link on the right side of this page " ask a question" and give more details. If you do not need help, convert this to a comment instead of an answer. Good luck
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,613
