跳转到主内容
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Full grey screen with pixels and lines after dropping in water?
Hi, so yesterday, I was taking photos while standing next to a pond and my phone slipped out my hands and fell into the pond. It was submerged fully for about 4 seconds before I got it out. After I got it out, I straight away took it apart and dried the the insides, taking out the battery as well. So, since I'm stupid, I put it back together while it was still a bit wet (I didn't notice it was) and turned it on. It worked for a couple of minutes then the back button didn't work and it just shut down. After repeatedly pressing the power button, it came up with a full fuzzy screen of grey, black and pink pixels and lines twice. The entire screen was like that... have I fried it? I really need answers so anything or any questions would be so helpful! Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
[] try putting it in a dry box w/ the battery removed for a couple of days (Airtight box with a dehumidifier or two. ).
[] It would be better if you have a hygrometer which will tell you if the air inside the dry box is dry enough - meaning the device is no longer wet- but it's not needed.
after 2 days, turn it on and see if it goes back to normal. Otherwise, it's likely fried then back up your files and bring it to a service center.
这个答案有帮助吗?
得分 0
添加一条评论
It’s probably water damaged, you might be able to save it by putting it in a bag with silica gel, but if that doesn’t work, your phone is fried. If you replace the screen and it works, or if you connect it to a micro-usb to hdmi and it displays, it might just be a water damaged screen. You’ll have to try it, though.
这个答案有帮助吗?
得分 0
1条评论:
It gets full grey when I connect it to charger but dosen't when I remove, it's a 2 in 1 tab / phone (Asus padfone) I could try by connecting it to the tab but it turns off the moment I disconnect from charger, when I connect it displays full grey things in the phone, I'm ready to use it always plugged in, it's my old old old tab, I want to save it for nostalgic reasons but can't repair it as it's a old device, I have loads of others so my parents won't accept for repair..
完成的
添加一条评论
添加你的答案
Emma Meyer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 1,703
