跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Black Screen after screen replacement
Went through some of the questions previously asked for the same problem/device. I've replaced several parts over the years on my iPhones without trouble, but recently when I tried to do a screen replacement, when I turn the phone on, I can see that the LCD lights up, but I only get a black screen. I can also tell that the TouchID is working, as my phone buzzes to let me know that I need to input my passcode upon rebooting the phone.
Since this is commonly asked, yes, I powered my phone down and disconnected my battery each time I went into my phone. I also brought the touchID, camera/speaker, and metal plate from my original screen over. I then went back to my original screen to see if maybe I had gotten a bad part, but my original screen is also only showing black. I'll need to wait until I can get home to put the circuitry under a microscope, but in the meantime, any suggestions or ideas as to what may be causing the problem? Just to reiterate, the screen does turn on, it just displays black. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
So I just went in again with a microscope, and inspected every connection and ribbon possible related to the screen replacement procedure. I can't find anything damaged or out of place. Any suggestions on what I can do next to troubleshoot the issue?
完成的
添加一条评论
3个答案
已选择的解决方案
Wound up purchasing a new screen with the ear piece and camera pre-installed and now it works again. Likely damaged something when transferring the ear piece and camera lens from broken screen to the newer one.
这个答案有帮助吗?
得分 1
添加一条评论
Hi there, Brian..
Three things to do.
1. have you tried another screen, could be a bad screen?
2. turn your device off, then get a flashlight and look if you can see the apple logo when turning it on, if you can barley see it the back light is gone, meaning you'll need to solider.
3.
The new screen do you have a black tape over by the red ring marked, if not and you see three "gold" stripes you might have shorted the phone.
https://i.imgur.com/FT6vU9d.png
这个答案有帮助吗?
得分 0
3条评论:
Number 1 was my first thought as well.
完成的
First of all, thanks for your response.
1. I tried the replacement screen, and then tried my original screen (which was severely cracked but working well.) Both only display black. Considering purchasing a new screen, but worry that because my old screen no longer works, the damage might not be with the screen.
2. I'm almost certain that the backlight is working. I can see it illuminate when I power the device on, it's just that the screen is empty. Shining light into it at power up doesn't reveal the Apple logo as would be expected.
3. Just took the phone apart again to check, and yes, there is in fact black tape over the area marked by the red ring.
完成的
Then I'm sorry, out of ideas.. Good luck.
完成的
添加一条评论
I’ve the same issue here. I put back the old screen and that works well. Swapped back the new one, and I see it’s flashing but no Apple logo or anything shows up. My best guess, the new display is just bad… Can I send it back and hope to get a good one as a replacement?
这个答案有帮助吗?
得分 0
1条评论:
iPhone 7 Plus
完成的
添加一条评论
添加你的答案
Brian Crawford 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 25
过去 30 天: 112
总计 10,322
