跳转到主内容
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
107 个问题 查看全部
How can I access my phone Data when my screen is broken?
I broke my screen and I can't even respond to a call therefore .my phone can't even work by touching. I had installed some ADB to debug the phone hence it only works as media PTP but when I try to access by USB. I see no document whatsoever.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
is your phone locked? if yes, can you unlock it?
完成的
添加一条评论
1个答案
已选择的解决方案
Unfortunately you will need the display to respond to touch.
If you use smart switch to help extract the data from it, or plugging the unit to a computer, will required permission to enter the unit. On that note, if you want the data in the phone repair the screen.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dallal bouguenina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 117
