跳转到主内容
加入维修社区 - 创建账户
The Nutri Ninja is a personal blender by Ninja Kitchen. This blender has no buttons: it starts blending when you insert the cup into the base. It is 900 watts.
Ninja IQ won't turn on
This is actually for :Ninja Auto‑iQ Nutri Ninja Blender, Platinum | BL480
The device won't turn on , any advice?
The lid is screwed tightly and locked in the appropriate direction.
Has anyone had this issue, or dissembled one before?
Any help is appreciated!
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
My Nijia Professional Food Processor began not starting some time ago. The tiny locking mechanism on the inner base unit stopped popping back into place when blender cups or upper processor unit removed. Using a point of a “dull” paring knife released it. However after doing that for about a year it now no longer pops back. Trying to learn if it can be repaired or if it’s almost cheaper to buy a new machine. I noted newer Ninjia models have the same type of locking mechanisms. Seems like a design issue.
完成的
添加一条评论
2个答案
Hi there...faced the same problem then solved it by cleaning one of the 2 microswitches located inside the unit. simple wipe to clean food buildup until you hear it click On/Off. Compare with other unit on the opposite side. You may have to replace it of damaged.....This is as far as my problem solving went...good luck!
这个答案有帮助吗?
得分 0
添加一条评论
Be sure the arrows are lined up on the lid. Then be sure the container is swivel ed in tightly. Should solve the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryan S 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 13,379
