跳转到主内容
加入维修社区 - 创建账户
Part of the Lenovo G Series of everyday laptops released in November 2012.
The power input on laptop has come loose
The input jack bit on my lenovo g580 has come lose and now moves away when i try to connect it to the power lead, anyone have any idea of how to fix it back in place, it's attached to the usb ports on the side that are also loose.
I've tried bracing it with some plsatic and gluing it in place but it wasn't strong enough
Cheers
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What glue did you use? It sounds like a piece of plastic holding the jack in place has got broken. You may find that 2-part epoxy resin will be more successful as yo can use the not only to stick with, but also to fill a void left by the broken plastic. But you'll have to reassemble the case before the epoxy goes rock solid as you may have to shave off any excess.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joshua Clay-Dennis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 210
