跳转到主内容
加入维修社区 - 创建账户
Pixel C is booting into waiting for fastboot command
Dear all,
I try to reset my google tablet Pixel C to the factory settings because I forgot my screen code.
I manage with the power on/off button and the sound up/down pushing for several seconds to manage to arrive to the screen which allow to go to Reboot into Android Recovery.
Once I go to this option I have the "No command" android screen.
I manage to escape this scree by pressing again the "up" button and the "On" one, but then I get this "Waiting for fastboot command...."
And I'm stuck here. Completely blocked.
My tablet is:
Google Smaug
HW VERSION: 5
BOOTLOADER VERSION: Google_Smaug.7900.27.0
Loock State: Locked
Thanks in advance for any suggestion.
Amelia
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
Did you ever come a solution? I am having a similar problem.
完成的
添加一条评论
3个答案
最有帮助的答案
You will need to get the phone out of fastboot mode.
To do this you will need to first hold the power + volume down buttons and maybe including volume up for 15 seconds to hard shut off the tablet.
The no command android screen was implemented in some recovery menus to hide the recovery menu from the user. You need to sometimes press and hold a combination of buttons to toggle the recovery menu from that screen.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, yes, I managed, but I still didn't manage to arrive to the hidden menu so to reboot the tablet. Any tips?
完成的
添加一条评论
Hey i had 5he same issue but all you need to do is hold the power button down by itself until it turns on showing the Google like regular. Hope this helps.
这个答案有帮助吗?
得分 2
1条评论:
Holding just the power worked for me. Thanks!!! It was a life saver
完成的
添加一条评论
When the tablet says “waiting for reboot command”, I decided to press the power button and the UP on the volume instead of pressing down. That managed to reset it and as of now, it is working again.
这个答案有帮助吗?
得分 0
1条评论:
Hi guys same is … can’t get it to reboot or change locked passcode
完成的
添加一条评论
添加你的答案
Amelia Neacsu 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 52
总计 15,221
