跳转到主内容
Repair and support for the third generation of the Flip portable speaker by JBL.
Why is my JBL making noise?
Does anyone know how to fix problem from this video: https://www.youtube.com/watch?v=5j9E8lN_...
i have the exact same problem, it is very anoying to play it half of the max volume...please help :(
I tried everything, to charge it, update it, with another device, when on full volume it plays normal for about 3 minutes and than it produces that sound and turns off and its not blown drivers because it sounds perfectly on max volume for 3 minutes and then the noise starts....please someone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Its happening to me also!
You find what to do about it?
完成的
Does your battery look too big for its spot? I mean, when I took my speaker to pieces, the plastic part that covers the battery seems to compress it , as if the battery was bigger than it should be. I can't put it back together anymore because of the battery, which is too big. It might be a stupid question but does someone know if a battery can get bigger when you take it into a plane?
完成的
my jbl flip 5 keeps turning up by itself plss help!!
完成的
Thank you so much.. it’s working 100% now. JBL CHARGE 4 working perfectly on max volume.
完成的
添加一条评论
5个答案
最有帮助的答案
I had the same problem and I just replaced the battery. No more noises at all!
这个答案有帮助吗?
得分 1
添加一条评论
Run the battery till its completely dead . charge till its 100% then try it
这个答案有帮助吗?
得分 0
5条评论:
Thanks for answer, I am going to try this
完成的
And did it work?
完成的
its working now. thank youuuu
完成的
that does not work for me
完成的
Thank you so much worked for me. JBL CHARGER 4 working perfectly now without the noice at max volume.
完成的
添加一条评论
My speaker makes this weird noise as well when i increase the volume especially when a song has base and its battery dies quick, how can i fix it?
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem, if I play more than half volume my JBL starts cracklin. However, if I plug it in and play full blast, the cracklin is gone. I reckon this has something to do with the battery, but I don't know how to fix it. Maybe replacing the battery?
这个答案有帮助吗?
得分 0
添加一条评论
My JBL speaker sometimes made noises when the speaker was powered on, but with nothing being played. So I remembered a device I bought for my car when I was playing audiobooks thru the speaker system using a plug in the glove box. It is called a ‘Ground Loop Isolator’ (mine is made by Pyle) and when I plugged it into the JBL speaker input, then plugged the device into the computer, the noise disappeared. Got it on Amazon and it now costs $12.79 (October 2020).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sava Andjelic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 39
总计 16,677
