跳转到主内容
The Toyota Celica is a sports car produced by Toyota between 1970 and 2006. The final generation was introduced in 1999 for the 2000 model year.
2 个问题 查看全部
Cabin electrical problem in my 2002 toyota celica
After replacing the battery, the radio, power door locks and windows, daytime lights, break light, signal lights, windshield wipers dashboard lights stop working etc stop working. I've checked the small fuses and are all good. What did I mess up and how can I fix it.?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hey Sam.
It's possible, I guess, that you may have shorted something out when changing the battery. Losing this array of functions suddenly isn't typical.
If it were me, I might replace the tail-light relay and see if this remedies some of the outages (several functions effected with this relay). If this turns out to be the case, you may then try to identify other relevant relays to test.
Also, just FYI, when checking fuses I’d recommend using a test light, rather than simply inspecting visually, as this also takes the integrity of contacts/pins into account.
Know this isn’t much help. Wish you luck.
这个答案有帮助吗?
得分 1
添加一条评论
did you wire it correctly , as well as check the wires for any wear
这个答案有帮助吗?
得分 0
1条评论:
Check the ground cable for corrosion and proper connection. Sometimes the corrosion is hidden under the insulation.
完成的
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 502
