跳转到主内容
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
33 个问题 查看全部
Why did the speedometer gauge stop working?
I replaced speed sensors and instrument cluster but gauge on speedometer doesn't move neither does the numbers on odometer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It is possible the electrical wire connecting the two is broken or grounding. You can use a multimeter to find out if there is a break in the wire.
这个答案有帮助吗?
得分 0
添加一条评论
Check for an open in the wire harness to the speed sensor form the PCM.
At the PCM connector C2 (middle one) Terminal 25 Dark Blue/Black and Terminal 28 Light Green/Black.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jimmy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 289
