跳转到主内容
加入维修社区 - 创建账户
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
The MacBook won't boot with battery connected.
Hi all,
I have bought a MBP Retina mid 2014 that has suffered liquid damage.
The laptop works fine however it will not turn on when the internal battery is connected. I have tried changing the battery with no results. It works fine when connected to a charger.
Have you every faced this problem? If so did you find a solution to it?
Kind Regards,
Michael
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
my first suggestion would be to replace the battery, but seing as you have done that;
water damage has likely caused damage to a PLD used to process the battery. Try using a 99% Isopropyl and a new Toothbrush to scrub hard at the board around the connector. be sure to include local ICs.
If this doesnt work, it is likely a failure inside the IC, which would then need to be replaced. requiring SMT soldering. this is a developed skillset, and i dont suggest attempting it without proper practice ahead of time.
这个答案有帮助吗?
得分 2
添加一条评论
Your logic board has a problem! Charging logic likely has spill damage. You'll need to open the system and carefully inspect the chips on both sides and clean the logic board of any corrosion hopefully that will fix things.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michal Piatek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 904
