跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s completely dead board troubleshooting
Hi,
I've got a customer's iPhone 5 that is completely dead. I got 0A on power supply (connected on battery connector) whit power button pressed and released.
I tried hard reset, DFU mode, replace the battery, replace the screen and power on only the board. However the phone doesn't respond to anything. I take off the shields and checked the board, but it looks ok, no corrosion points, no components smoked.
I would like help to start the board analysis. what is the better points to check in this situation? What is the lines and the values that I need to check?
Thanks
Felipe
UPDATE: I just put the phone to charge and after some minutes the all phone warmed up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
New Update: I put a new battery and new charging port and plugged on wall charger.
After a few seconds the coil L16 got hot and after more 1 or 2 seconds the coil L18 too.
完成的
remove and replace both, theres possibly a problem with the pmic as i had similar problems on a 5s
完成的
添加一条评论
1个答案
已选择的解决方案
When dealing with a “dead” phone, you have to start at the beginning and check PP_BATT_VCC, PP_VCC_MAIN and PP5V0_USB. I would start by checking to see if those rails are shorted to ground. If one of these rails is shorted to ground, then you will need to identify what is causing the short. It could be a bad decoupling capacitor, conductive debris or defective IC that is directly supplied by those rails.
If they are not shorted, then you can connect, preferably, a known-good battery (or a current limited DC power supply with the appropriate connector adapter) to see what voltage you measure. If the voltage is low or lower than the battery voltage (which you measured before plugging it in ;>), then there could be a short circuit on secondary subsystem that is causing the battery or DCPS to be current-limited.
Then you move onto the PMIC and check the voltage rails it generates:
  • The PMIC generates a lot of voltage rails. They are all important (for obvious reasons) but the ones to check first are as follows: PP_CPU, PP_GPU, PP1V8_SDRAM, PP1V2_SDRAM, PP_VAR_SOC, PP0V95_FIXED_SOC, PP3V0_Tristar, PP3V0_NAND, PP1V8_ALWAYS and PP1V0.
  • The PMIC also generates, what I would consider secondary, yet still important voltage rails for the following sub-systems: PP3V0_MESA, PP1V8_VA_L19_L67, PP3V0_PROX_ALS, PP3V0_PROX_IRLED, PP3V0_IMU, PP3V3_USB
Note: The net names change slightly from one iPhone model to another
Start probing and report back.
这个答案有帮助吗?
得分 1
3条评论:
Hi
The board is: 820-3292-A
I connected the board in a power supply configured whit 3.8v and limited to 150mA.
All tested points the power supply keep these parameters: 3.8V / 0.088A ~ 0.092A and I got the measurements only plugging the power supply, I not pressed the power button
完成的
PP_VCC_MAIN (C270) = no shorted / 3.78V
PP_BATT_VCC (C387) = no shorted / 3.78V
PP5V0_USB_CONN (TP57) = no shorted / 0.0V
PP5V0_USB_PORT (C272) = no shorted / 0.0V
PP1V8_SDRAM (C293) = 0.010 ohms / 0.0V
PP1V2_SDRAM (C308) = 0.420 ohms / 0.0V
PP3V0_NAND (C182) = 1.089 ohms / 0.0V
PP1V0 (C442) = 0.980 ohms / 0.0v
PP1V8_VA_L19_L67 (C104) = 1.100 ohms / 0.0V
PP3V0_PROX_ALS (FL45) = 1.094 ohms / 0.0v
PP3V0_PROX_IRLED (C44) = 1.093 / 0.0V
PP3V0_IMU (C347) = 1.137 ohms / 0.0V
PP3V3_USB (C35) = 1.143 ohms / 0.0V
PP1V8_ALWAYS = I cant find a "test point" to get the parameters
I not fount any reference about these nets
PP_CPU
PP_GPU
PP_VAR_SOC
PP0V95_FIXED_SOC
PP3V0_Tristar
PP3V0_MESA
So, all the PP points are 0, so can I assume that PCMI is "burned"?
完成的
Maybe, but limiting the input power to 150mA is probably not enough.
完成的
添加一条评论
添加你的答案
Felipe Kashiwagura 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 2,000
