跳转到主内容
Bissell's Bolt ION 2-in-1 Cordless for large rooms or smaller areas with detachable, handheld vacuum. Model number: 1312.
Why is dirt escaping from my vacuum?
The dirt is spilling out of my vacuum and will not suck in more dirt.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Dirt may be escaping from your vacuum due to one or two things:
1. The filter on the inside of the dirt trap bag may be loose or unlocked. This may cause dirt and dust to flow freely and escape through either the detachable portion of your vacuum or the end by the head and brush roll.
2. Your handheld portion which holds the filter may be loose or detached at a certain point. Re-check to make sure that it is secure and fastened.
Hope this helps.
Ben
这个答案有帮助吗?
得分 0
1条评论:
Ok, how do I fix this problem ?
完成的
添加一条评论
添加你的答案
jasmine soria-gamino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 244
