跳转到主内容
Repair guides for Android cell phones manufactured by ALCATEL.
Why can't I make or get a call my tracfone has 500 minutes available
i was cut off in the middle of phone call. Now i cannot receive or send calls. I have a tracfone Alcatel and have 500 minutes left.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论:
Have you verified that you have enough service days?
完成的
How do I check my minutes
完成的
添加一条评论
1个答案
assuming you have called your Carrier's support lines.
Then you may want to check if the device is blacklisted. (if you got the device used, someone may have reported it stolen or missing)
id then try a factory reset, and put it back to its default settings.
at this point, you can look into hardware issues. (Antenna, Baseband IC, or board fails.) most of these i suggest hiring a professional to look at.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
margaret wenzel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 6,732
