Question about home button replacement
So, I have this iPad mini 4 which the Touch ID works, but the home button doesn’t. Is there a way to just replace the home button clicking part?
Have you recently replaced the screen or have had it opened before the problem?
Yes, you can replace the home button to get it working again or you can open it to make sure it is making proper contact with the pads that make the physical connection. Here is a post that describes the issue a bit better:
iPad Mini Home Button Not Working After Digitizer Replacement
这个答案有帮助吗?
Yes, I have done a screen replacement before. Well during that time, a rubber thing was thorn apart and I just left it in my drawer. How would I go about just replacing the home button part instead of the whole Touch ID + home button? Would the Touch ID still work?
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 14
总计 1,529
