跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
3d touch and touch id not working..
The touchscreen i.e. 2d touch of my phone works fine but the 3d touch isn’t responding...?
I tried reseting the phone but it just avoids to work..
Even the Touch ID is not working even though the home button works just fine but the finger print isn’t sensed......
I had a screen replacement once.
I would be nice if you help me in finding the problem with it...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Hi,
Both the 3D Touch and home button run through the same cable, I would highly suggest trying another screen, as there may be damage in the cable. :-)
这个答案有帮助吗?
得分 3
3条评论:
Are you sure as I have problem only with my Touch ID but the home button still works.
完成的
Yes, I am quite positive, try another screen and let me know, also make sure it’s not a poor copy screen
完成的
Sure will do that..!
完成的
添加一条评论
I had the same problem, and after i replaced it with the old screen it all worked and I found out that some how the little cable was broken:(
这个答案有帮助吗?
得分 1
1条评论:
I e replaced 2 screens and still can’t get working properly
完成的
添加一条评论
I have 3Dtouch, touchID and force touch not working after I opened My iphone7plus, maybe changing screen I can solve the problem ?
这个答案有帮助吗?
得分 0
1条评论:
I’m pretty sure you have damage one of the flex cable ( the lower one) it’s very easy to . i have done it a few times:( So you you have to be very very very carefull when you open up your phone.
完成的
添加一条评论
I have this problem too with my iPhone 8 Plus, the flex cable doesn’t even seem damaged at all.
这个答案有帮助吗?
得分 0
3条评论:
It is for sure damaged, change backlight and all will be right
完成的
When I opened my 7 plus I couldn’t see broken flex till I put away backlight screen protection. If you opened your iPhone and from that moment Touch ID and home button doesn’t worked anymore, is for sure the damaged flex. Don’t change any other things, don’t’ change home button, just be very very very careful and change back light. By change only back light your screen will be good as usual. if you change all the screen with a preassebled as GIGA FIXXO ON AMAZON, it will be very easy and secure, but you will not have the original qualiti of apple screen
完成的
Attention, flex Brocken is not the one you see near the home button!! The flex Brocken is under the protection of the screen. Don’t do it by yourself become is too risky, go to a Chinese or to a Irepair, and say that you want change backlight (15€ Part cost)
完成的
添加一条评论
添加你的答案
Shivam Patil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 3,366
