跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
ipad air lte 2014
Hello to all. I bought in 2014 an ipad air 1 model.
was used very few times .. at max 10. The part of the time was always turned off and placed in the closet.
about 5 months ago I used it and it was all right, only that once turned off and restarted only 10 days ago, nothing .. dead.
I tried the dfu, pc recovery, brought to the apple center, but nothing ... so was it perfect and died so suddenly?
the apple center told me that they can not open it .. so if I plug it in to the charger the screen turns black on but nothing more happens
do you know how to help me?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
how long did you leave it on charge as it could take a while
完成的
for about 20 hours ... connecting the battery charger the screen turns on but stays black, but as soon as the cable is disconnected, it shuts off complete
完成的
添加一条评论
1个答案
已选择的解决方案
There's no obvious reason for a device to fail for just sitting in a closet. As Daniel suggested, you're battery is probably seriously depleted and it will require some time to properly charge. I might add, you really need to plug it into the original Apple 12W charging brick that came with it. A regular computer USB port can't supply much current and it really struggles to charge an iPad battery. So plug it into the brick and let it charge for a day.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
daniele90ct 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 100
