跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
New battery causing phone to be slow under 10%
So I recently decided to put a new battery in my IPhone 6s Plus as the old one wasn’t holding charge. I ordered a battery from another source and installed it. However, when my phone would get below 10% battery remaining, it would become very slow. As soon as I would plug it in it would work like normal. I figured this would be from a inferior battery, so I ordered one from iFixit. However, the new battery does the exact same thing. Does anyone know why I’m experiencing this and how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
10个答案
最有帮助的答案
Check the Battery settings and see if this applies to you:
https://support.apple.com/en-us/HT205234
这个答案有帮助吗?
得分 2
1条评论:
No, I’m not turning on low power mode. As soon as my phone gets below 10% battery, it becomes very laggy and unusable until I plug it back in. This didn’t happen with my old battery
完成的
添加一条评论
I have the same problem as well. Did you find a way to fix it?
这个答案有帮助吗?
得分 0
1条评论:
Sorry, I never found an answer. Just living with it as it only happens when the battery is low. I'm sure there is an answer out there somewhere but I haven't found it yet.
完成的
添加一条评论
Same thing happens to me but when I hit 6%
这个答案有帮助吗?
得分 0
2条评论:
Yes, it is very frustrating as the phone becomes unusable. Hopefully someone will stumble upon an answer.
完成的
It started doing it at 35% now ugh
完成的
添加一条评论
Replace it again, if the problem persists, feel free to tag me in a reply that you have tried the part, because we could possibly be looking at something super fun :)
这个答案有帮助吗?
得分 0
2条评论:
@toreskey I'm on my third replacement battery! The first two were from different suppliers but the current one is from iFixit, and they all have the same proble for me.
完成的
Are you able to get me a very close picture of the battery connector on the logic board of the phone?
完成的
添加一条评论
Add another of this issue, I only noticed it recently, because I rarely let my battery get under 50%, but somewhere between 10-20% this slow down is kicking in for me with an ifixit supplied battery, not particularly happy.. especially as a month later apple did the cheap battery replacement programme.
这个答案有帮助吗?
得分 0
添加一条评论
When you go below 20% and notice the lag can you try running Lirum Device Info Lite and check if it reports your device as using 100% CPU? That is what mine does but not sure why yet. Mine is an iPhone 6S, iOS 12.1, battery from ebay with apple logo covered with marker pen.
这个答案有帮助吗?
得分 0
1条评论:
at %50 my CPU is %100. When I connect to power source CPU goes down to %20-25. IOS 12.1, 6s+, OEM battery (it does not show battery info in setting)
完成的
添加一条评论
i had the same problem, i resolved it by doing a back up and restoring the backup.
i suppose it can work by updating the ios too
这个答案有帮助吗?
得分 0
添加一条评论
What probably happened is that the connector that you connect the battery to on the logic board is damaged. Either you can replace the logic board, which I would say isn’t worth it, or you can go to a logic board repair shop (there are a lot of them on eBay).
这个答案有帮助吗?
得分 0
添加一条评论
I believe that there is a bug (or a feature!) in the iOS kernel that when the battery level is low, it attempts to send commands to the battery which fail on non-genuine batteries, causing the commands to be sent repeatedly, causing the kernel to use 100% CPU and lock the phone’s UI up, and in my experience if I do manage to get a call out the audio is choppy. My solution was to find a genuine used battery from a reputable seller on eBay that deals in iPhone recycling, unfortunately with this particular seller it is pot luck to find one with a good health value.
这个答案有帮助吗?
得分 0
添加一条评论
I will suggest you to change this one and try new one. I hope this will work. All the best!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lucas Idstrom 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 17
总计 4,153
