跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
How to remove earpiece
I've hunted around for this, but I haven't been able to find it.
I've repaired quite a few iphones so am not a novice. However I've yet to be able to work out how to unclip the actual earpiece from the mid frame.
I can remove the sensor flex assembly, but not the actual earpiece from underneath.
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
you have to remove it from the backside. remove the ribbon then you can remove the speaker. if not careful, you will damage it. a non issue if you are replacing it. i use a microscope to do it and keep it intact. use a small pick or pointy tool.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Zammett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,441
