跳转到主内容
加入维修社区 - 创建账户
My MacBook won't turn on
I bought a macbook from someone and I can't seem to get it to turn on. I've tried everything there is, the SMC reset, the NVRAM reset and I also opened it up and unplugged the battery.
There is no chance in getting my money back so is there any other way to do this?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
are you getting a green light on the charger
完成的
No, there is no light on the LED of the charger
完成的
We're having the same problem, but the charger light is green.
完成的
添加一条评论
1个答案
its either an issue with the charger or the logic board, you could try another charger or you will need to take the board out and look around to see if you can see any damage, this might help. https://www.youtube.com/watch?v=v_8yxaEL...
这个答案有帮助吗?
得分 0
1条评论:
It's probably the logic board then. I borrowed the charger from someone else so that definitely works.
Thanks for replying
完成的
添加一条评论
添加你的答案
notanexpert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 171
