跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Why isn't my iPhone recieving touch imputs
I replaced the screen, only for it to not get any touch signals. I then put on the old one and same issue. I have since updated the firmware and still cannot find a solution. Any tips?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What firmware version was installed and was your old one working before changing to the new one?
完成的
It was running 11.0 i think. It was working until i attempted to install the new screen. I tried updating it because of iOS bricking 3rd party screens but that hasn't worked
完成的
添加一条评论
1个答案
最有帮助的答案
Specifically with iOS 11 it is extra important that the battery is unplugged when any cables are being detached. I would try to clip in the new part (battery unplugged) then plug in the battery and do a soft reset. If that doesn’t work unplug battery and plug in original and try again. If that part is still the same then it is possible that the pins on the motherboard where your digitizer ribbon connect may be damaged. Let me know if that works though
这个答案有帮助吗?
得分 1
2条评论:
Hello. Unfortunately, when I reinstalled the screen with the battery unplugged, it still wasn't working. I don't think the issue is with the ribbon cable either, as neither screens work. Is the only possibility a bad motherboard? I have experience in computers and I don't recognize any bent or damaged pins.
完成的
It also seems to reboot when I turn it on. It shows the apple logo, then it flickers, and then it starts up. Doesn't seem normal to me
完成的
添加一条评论
添加你的答案
Jon Muir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 111
