跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
all PP_LDO lines missing
Hi,
I have an iPhone 6 board which seems to have all the PP_LDO lines missing (all of them). They are not shorted, as the resistance to ground reads in megaohms, but when the board is powered on (screen shows restore with iPhone) the lines are absent.
I want to ask if this is normal when the phone is in the DFU mode? More or less everything is disconnected from the logic board.
Unfortunately I do not have a known good board to check that.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
most of these lines seem to lead to U_PMICRF so i would check around that area
完成的
This is the point. I want to distinguish between faulty baseband and faulty baseband PMIC. On the other hand it might be that these lines are software-activated and it is not that weird that these lines are missing.
完成的
添加一条评论
1个答案
已选择的解决方案
Those lines should be active when you power up the logic board. Have you also checked the VREG_SMPS1 (2/3/4) lines to see if they are generating any output voltages?
I would start by confirming that VBATT_S1 (2/3/4) are present and not shorted (they shouldn't be because they are directly connected to VCC_MAIN). If none or most of the outputs voltages are present, then I would suspect the PMICRF first. Be careful when you replace it because there is a trailer park's worth of caps right next to it and when they start shifting around, they tend to bridge easily and it's hard to separate them.
这个答案有帮助吗?
得分 3
5条评论:
Does the DFU mode play a role here?
完成的
I can't say for certain...I'd have to check that condition.
完成的
Anyway VBATT_S1 (2/3/4) shows 4V to ground. VREG SMPS1 (2,3,4) are all missing. so it seems its likely a baseband PMIC ?
完成的
Yeah, that's my thinking.
完成的
I have also checked now that the VREG_SMPS1 (2,3,4) are missing during my attempted restore through iTunes (i soldered jumper test wires to the capacitors and monitored those lines on the oscilloscope - flat zero all the time)
完成的
添加一条评论
添加你的答案
Mateusz Lacki 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 5
总计 636
