跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
iPhone in loop and won't turn on after dropping in bathtub
I think it's a 7 or 7+ idk...Stupid old me dropped my phone in the bathtub while trying to listen to some answer a phone call! It seemed fine initially, just looked like it had a bit of water damage with the screen but nothing a bit of drying couldn't fix. I took off the otter box case right away and towel dried it first, and I tested if all the gears and whistles worked and everything worked just fine except it was stuck in headphones mode. No problem, just restart it, right? Wrong! I go to do that and then it went in a continuous loop of apple logo then black screen for about an hour while I tried to restart it. I tried to connect it to my computer and iTunes didn't recognize it. It turned back on for a hot second and showed it was charging before going back into that stupid loop again. I put it in DFU mode but again iTunes didn't recognize my phone and so I just tried restarting it and back to the loop, before it completely went off and nothing's going on with the screen now. I also dried it with a hair dryer and it's dry as a bone now and plugged into my wall. I don't know what to do! I have a busy af week and literally can't function professionally without a phone for this week of all weeks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hello!
Once the phone is exposed to liquid, the battery needs to be replaced. Chances are the battery is dead, which is why the phone will not boot. iPhones will only show the logo, then shut off if it doesn't detect a battery.
Take it in to a repair shop and have it diagnosed, the water damage/corrosion cleared out, and the battery replaced. Hopefully that solves it.
It's best that you don't plug it into the charger as it will make the make the corrosion worse and likely damage more of the motherboard. :(
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ameera Iftekhar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 428
