跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Part of the touch screen is not functioning
I recently replaced a broken display screen.
When I turn it on, it asks for my passcode
Unfortunately the top row of the keypad in not accepting my input
What is causing this, and how can I fix it ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Either you have not seated the connector for the digitizer correctly or the digitizer is defective on your new screen. Turn it off, open it and disconnect the battery. Reseat the connectors again and test it by plugging in the battery and powering on before assembling everything. If it still does not work...(ALWAYS Disconnect battery before plugging in or unplugging connectors) you most likely have a defective screen assembly.
And as Jim suggested, clean the connectors and look for damage.
Does your old one work? If so, you can try connecting it back up to test with. Also, make sure each screw you remove goes back into the same hole it came out of and do not mix them up. IT MATTERS and can cause damage to the Logic board if you do not.
Post back the results to help others troubleshoot their devices with similar issues.
Good Luck!
这个答案有帮助吗?
得分 2
1条评论:
I reinstalled several times with the same result so I took it to a shop.
It was fixed and I am told the part was defective. Will see if I can return same
完成的
添加一条评论
最有帮助的答案
Sounds like dirt in the connector or there's a missing pin in the connector . try opening the phone again and cleaning the digitizer connector on both the screen side and the motherboard side , use ip alcohol with a 90%+ rating look closely at the connector and make sure all the pins are present and that none are bent up or down to where they wont make contact.Hope this helps
这个答案有帮助吗?
得分 2
1条评论:
see my comment to michael@teetopp
完成的
添加一条评论
添加你的答案
timfriedmann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 91
