跳转到主内容
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 个问题 查看全部
Why is my 2001 pontiac grand am gt still over heating?
I have replaced my resivor cap, water pump, thermostat, and bled it added new 50/50 had it flushed and cleaned twice and my car is still overheating not long after it warms up. It makes a bubbling sound and runs hot and the temp rises . I was told from a friend that is a mechanic it sounds to him like the intake gasket needs replaced. I am lost when it comes to cars. Any help please ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
This sounds like head gaskets to me. I was an ASE Master Certified tech with L1 and X1 certifications until I chose to pursue electronics repair due to back problems. These GM engines are well known for the intake gaskets leaking both internally and externally but weren't normally the cause of overheating unless the coolant level was low due to loss/leaking. Your description of "bubbling" further supports the head gasket theory since the head gasket (when failing) will allow combustion gasses from the cylinder into the cooling system. These gasses create pockets throughout your cooling system, causing poor coolant circulation, and sometimes a vaporlock that prevents any circulation at all, all of which will result in overheating situations. Sometimes you can see these bubbles when the engine is run with the radiator/or reservoir cap off ( EXCERSISE CAUTION WHEN WORKING ON A HOT ENGINE!!). A local shop should be able to verify the head gasket failure with a test. If they are found to be faulty, the repair would also entail replacement of the intake gaskets, so that issue shouldn't plague you in the future. Good luck, hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
I have a 2002 grand am and i got new water pump and thermoatate put in and after driving for 15 mins it is still over heating please
这个答案有帮助吗?
得分 0
1条评论:
Did you ever get it fixed
完成的
添加一条评论
添加你的答案
casey dixon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,582
