CD door won't open
'CD door
The door to the CD will not open.
What can I do to open it? When I press the button, the display says 'open,' but it will not.
I presume this is the kind of CD drive with a tray which comes out when you press Eject and that you've tried inserting a straightened out paper clip into the hole in the front panel. I've seen this fault a few times. You need to remove the complete CD drive from the unit and open it up if it's inside a metal case.
I've described how to deal with this fault in the Restart Wiki.
这个答案有帮助吗?
I would stick a paper clip in it but where?
这个答案有帮助吗?
Take a butter knife and GENTLY slide under the CD tray, on the left until you feel the catch release
Pamela Fowler, Thank you! This worked!!!
过去 24 小时: 8
过去 7 天: 32
过去 30 天: 127
总计 10,824
1条评论
Do you hear anything when you press open?
由 George A. 完成的
