跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Circuit for power button
Can anyone tell me the circuit for the power ribbon. I want to test if the power button is electrically doing what it should - I assume that when it is pressed it creates a short between two of the contacts on the end of the ribbon connector. Can someone confirm that and tell me which two are shorted or open circuited if it works the other way.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Based on the schematic, when the power button is pressed, the GPIO_BTN_ONOFF_L line is brought to a LOW condition (brought to ground). That sends a signal to the PMIC.
The line does go through a filter (L2613), resistor (R2613) and it is clamped by a diode (DZ2613) on the logic board so any one of those components could be causing issues.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John Tipper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 172
