Normally this happens after a crash while updating firmware.
Try booting the phone in safe mode and recovery mode.
If you can ask the customer to longing in google account and if he's OK with resetting the phone
Press and then hold the Home and Volume UP keys, then press and hold the Power key.
When the Samsung Galaxy S7 shows on the screen, release the Power key but continue holding the Home and Volume Up keys.
When the Android logo shows, you may release both keys and leave the phone be for about 30 to 60 seconds.
NOTE: The “Installing system update” message may show on the screen for several seconds before displaying the Android system recovery menu. This is just the first phase of the entire process.
Using the Volume Down key, navigate through the options and highlight ‘wipe data / factory reset.’
Once highlighted, you may press the Power key to select it.
Now highlight the option ‘Yes — delete all user data’ using the Volume Down key and press the Power button to select it.
Wait until the phone is finished doing the Master Reset. Once completed, highlight ----Rebooting system now then press the Power key. The phone will now reboot .........bit longer than usual.
7条评论
Check for water damage; after water damage the flashlight is one indicator of a short somewhere.
由 Gigabit87898 完成的
If it heats up it’s probably water damage. It’s probably shorting a main voltage rail, heating up a lot of components and not a single one.
由 Gigabit87898 完成的
I don't see any signs of water damage or any past corrosion inside. We're calling it a dud and he's going to try to get a warranty swap through Samsung, in my call with them they said it was still under warranty. So worth a shot!
由 Brandon Flegel 完成的
Hey @gigabit87898 my phone constantly notifies me about moisture in usb charging port and also the flashlight doesnt work sometimes. Phone is conpletely dry, i eveb dried ut with a hair dryer. What do you suggest? And ive also checked that its a hardware problem, not software.
由 Nimra Ehsan 完成的
I'm working on a Samsung Note 8 with this exact same issue. I have just barely started looking at it but I was able to locate some damage near the SIM tray. Not sure how it happened but the customer has had it fixed previously. I will update as I learn more. Just trying to figure out what these are responsible for
由 Dustin Wood 完成的
显示更多的2条评论
