跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Touch ID not working after replacing home button cable
Hi, I recently replaced my home button cable after accidentally ripping the home button cable while replacing my phone's screen, I bought this part https://www.amazon.com/dp/B00XNA80Z6?ref... After successfully installing it, I found the the home button works too go home and things like that. However the touch ID does not work. Any suggestions?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Unfortunately, only the original home button will work for TouchID. The home button and logic board are paired, so you'd have to replace both if you want TouchID functionality. Here's another discussion about it in case you're curious: Any possibility to replace Homebutton AND have Touch ID still working?.
这个答案有帮助吗?
得分 2
2条评论:
UPDATE: I just found this article that shows a glimpse of hope on the horizon (pun intended): https://ios.gadgethacks.com/news/after-e...
完成的
Oh I had thought since it was just the cable or would be fine
完成的
添加一条评论
添加你的答案
Monica Alexander 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 5,978
