跳转到主内容
Repair guides and support for Android tablets made by Dopo, also known as Double Power.
34 个问题 查看全部
Need to Reset my Password
I cannot remember my original password (password hint did not help) and do not know how to reset it. The tablet states "This feature requires removable media, such as a USB. Please connect a USB Flash Drive, and then try again." This tablet doesn't even have a port for a USB drive. How do I go about resetting my password now?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Seems you have Windows tablet read below and follow the instructions.
You need to choose the second option to reset from your Windows 8 tablet's logon screen. See how to reset Windows 8 password before performing following steps:
Step 1: Start and go to the login screen, look for the power icon on the lower right hand corner of your tablet's screen. Tap on it.
Step 2: Press and hold the Shift key.
Step 3: As the Shift key is clicked or pressed, simultaneously tap on Restart, the tablet will then restart. Now, you will see a screen where you will be asked to choose an option. Tap on Troubleshoot.
Step 4: Finally, choose Reset option, this will begin the factory reset. When using this method, it is best to have a keyboard connected with your Windows 8 tablet for the easy following of the steps. In case you do not have a keyboard you can connect to, start the On-Screen keyboard, which can be found on the options at the lower left hand corner of your tablet. You can find an icon there that represents the Ease of Access. Tap on it then choose the on-screen keyboard. Thanks hopefully your problem will resolve.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for the support provided above however, it just kept resetting my tablet. Apparently I had to turn it off and then hold down the volume up and the power button at the same time for about 5-10 seconds which then took me to the troubleshoot screen you spoke about above. From there, I was able to follow your reset instructions. Thanks again!
完成的
添加一条评论
添加你的答案
Rachel Rabe 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 8
总计 1,235
