跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Blank screen , no video a1418
Hi,
I am having problems with my imac 21'' late 2012 A1418. This piece has been burned out and I don't know what kind of piece it is exactly, and I would need to replace it.
Please, if someone here has a similar 21'' imac which is opened at this moment and can send me a picture of this piece, that could help me very much to know what kind of piece I have to replace.
The computer can be turned on because I can hear the ring bell when it is starting but it gets blank screen.
Thank you very much
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
8个答案
Here you go, hope its not too late ;)
Maybe someone with the proper scematics of the board could tell you the exact model number.
Cheers
这个答案有帮助吗?
得分 0
添加一条评论
Hello,
This is the classic burn by the 12v lcd fuse.
The “P” fuse as it is commonly referred to feeds the 12v through the LDVS connector to the display panel.
Scrap away all the charred and burnt bits on the PCB and replace the fuse. ( available on Ebay ) check the decoupling cap next to it, it nearly aways is OK.
Inspect the ldvs connector and the ribbon for shorts or damage and replace as necessary
Most boards like this are salvageable
这个答案有帮助吗?
得分 0
添加一条评论
Hi peter. Any more info on how to replace the PFuse? I have this issue which needs resolving.
这个答案有帮助吗?
得分 0
添加一条评论
If you are not competent at soldering. I would suggest you send us the board for repair.
这个答案有帮助吗?
得分 0
1条评论:
Where do I send it and how do I contact you directly? What is the average price for this repair?
完成的
添加一条评论
I read that you call it “12v lcd fuse” or P-fuse.
On other sites it is called reference designator L9100 which is a 250ohm ferrite bead.
I for sure know mine is blown on my A1418 Imac, but what do I have to order?
这个答案有帮助吗?
得分 0
添加一条评论
Hello
It is a 12 volt fuse marked with a P
It protects the 12 volt rail feeding the LCD via the LDVS connector.
L9100 is not the same thing
这个答案有帮助吗?
得分 0
添加一条评论
Great, thanx for your answer.
Is it the same fuse as used in macbooks then?
这个答案有帮助吗?
得分 0
添加一条评论
Hello. The fuse that has the “p” on it blows quite often if the screen comes loose and pulls the cable out or is turned on when disconnected. The fuse is the same as that used in the early macbooks and can be raided from an old board. Use a hot air soldering station to pull out the old one but use an iron to replace it so you dont blow components off the board.
Thank you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bizz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 1,477
