跳转到主内容
The Sony Extra Bass Headphones Model: MDR-XB450AP, are a high end pair of headphones that are manufactured by Sony. Features an omni-directional microphone for Bluetooth capabilities.
19 个问题 查看全部
Right side not working
In the gym, i the wire of my headphones got pulled during my workout. Since then, I the right side is not working. I followed a guide to disassemble the right side of the headphones and found that the solders to the speaker were intact. Everything seems fine, I don't doubt any damage to the speaker, as they were working fine just before the wire got pulled. What else could the problem be? I am attaching a few photos after disassembly, please look into them and report the cause as to why the right side is not working.
P.S. The left side is working fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
8条评论
Hey Vikram, I have same problem with my headphones? Did the other mentioned solution worked?
完成的
Mawose, I'm sorry for making you wait for the 3 days for the anwer, but the answer did work. Actually, I found out that this problem often occurs because the one of the solders at the jack has got loose, or at times broken.
完成的
What part is the broken part?
完成的
It's the same problem of my headphone but I can't find the source of problem can you help me
完成的
Can you provide a picture of the problem? Since i dismantle my headphone i don't see any problem in the wire they're still intact.
完成的
显示更多的3条评论
添加一条评论
1个答案
最有帮助的答案
Your head phones wire broke off from somewhere in between the pin and the right side speaker connection which is quite thin .
这个答案有帮助吗?
得分 1
1条评论:
thank you Chris
完成的
添加一条评论
添加你的答案
Vikram Choudhary 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 5,728
