跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
I broke my screen. Cracks on the lower right side, what should I buy?
My screen condition :
https://imgur.com/a/qTzBr
https://imgur.com/a/RQJyY
What part should i buy? I'm very new to macs, and I don't have a lot money :( So, Anyone can recomend me a new/used part, prefferably cheap (I can't afford anything more than 250 USD actually :( I'm a student on a third world country), and ship internationally.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
A1707 assemblies are very expensive and difficult to get at the moment; you definitely won't get anything under 250$ (if you can even get one). Just the screen panel itself costs around £200, and companies will charge a premium for replacing the panel, since it is fairly complex.
You won't find the part for this price for at least a year, when factory rejects start becoming available (and even then, it could still be more expensive), so you might have to save up
这个答案有帮助吗?
得分 4
4条评论:
I've found some screen replacements part on alibaba. Should I trust it?
完成的
If you have seen any for around £200, these are just screen panels and you will have difficulty replacing just the screen panel if you have no prior experience (and can get dust/scratches behind the screen if not done correctly).
Assemblies for the A1707 (15" model) are going for £400+ at the moment, so it is out of your price range
完成的
Let's say i've found a guy that could do it, is it still worth taking the price?
完成的
There would be no one willing to replace the LCD panel for under the price you are looking for (unless they are willing to work for free). If they are willing to do it for a very low price, expect to see dust, scratches and marks through the new screen, because they would have likely never done this repair before and damaged the backlight sheets behind the screen.
The part may not also be great; 2015 onward LCD panels have a high chance of having blue/purple blemishes which can be seen on a black screen if you get a bad part.
Anyone who replaces the LCD panels on Retina's will want a decent amount of money for doing it properly; it is a miserable process and there is a lot which can go wrong. If you have found someone you trust though, or are not worried about how it looks, go for it :)
完成的
添加一条评论
添加你的答案
Afif Yoga Pradana 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 218
