跳转到主内容
加入维修社区 - 创建账户
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
Half of touch screen working
Hi,
My iPad mini 2 (A1489) has only half of its touch screen working.
I opened and verify the connectors: everything seems ok. No missing pins.
I think I see copper through a tiny dent in the cable from the digitizer to the logic board. Exactly where the cable folds.
Should I buy a new digitizer right away or is there any other thing I should check before buying that part?
Also, anything I should look for to avoid buying a bad touch screen? I saw prices range from 10$ to 30$
Can I easily buy a screen without IC connector and just take it from my old screen?
(I am trying to fix this on a budget...)
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It sounds like the dent in the ribbon is your problem - I'm afraid you need to bite the bullet and order that new digitiser unless your day job is as a brain surgeon! It'll come complete with the ribbon and connector so you can't save anything by transferring a connector from the old one - even if you were a whizz at microsoldering and competent to do so.
As for which to go for, my general rule is avoid the very top of the market - you may be being overcharged for an OEM product which is no better than an aftermarket one, and avoid the bottom - it may be rubbish. And make sure you go for a vendor who has a credible returns policy.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christian Beland 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 175
