跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Coming to white screen with apple logo, stays frozen, how to restore?
I have an iphone that has a white screen with the apple logo, does not continue to boot.
No error on the screen. No options. Can reboot, but the same problem comes back each time.
Is there a way to restore this to factory settings?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes, use DFU recovery. Power off the iPhone then plug it into iTunes while holding the home button down. You will see the connect to iTunes screen display. From iTunes select restore. If it gives the option to Update, try that first as it will preserve any locally stored data. I think from iOS 10 up that restore is equivalent to the traditional DFU recovery. If that doesn't work then go through same steps until you get to the Connect to iTunes screen display. From there, hold the home button down at the same time while holding the power/sleep wake button until the screen goes blank. Once it does, wait a couple of seconds the release the power button while still holding the home button down. If you get a recovery prompt in iTunes then you were successful. Select restore then go from there. If not, then try the process again.
这个答案有帮助吗?
得分 1
添加一条评论
Also in 3utools (which you can use instead of iTunes) you can tick the option of retain users data while flashing.
Most likely while the phone is in DFU mode iTunes may not allow you to do an update on the phone and you may require to use 3utools to do an update of the iPhone in DFU mode.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ryan Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,423
