跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Spill 91% alc/Keybrd replaced/logic board wrks/Pwr bttn still not work
My beautiful A1278 Macbook Pro mid 2012 13" had 91% alcohol spilled on it and it sat in the alcohol, inside a bag, for a day. (I was trying to kill its Ebloa.)
The back panel was taken off and everything was carefully dried as much as possible. (I gave it a blow job with compressed air.) It didn't power up until magsafe charger was plugged in. The inside row of keys did not work (a-row of keys and z-row of keys) and power button did not work.
After a few days, most of the a-row and z-row of keys started working but still no power button. (This whole time the back light on the keys was working but no light for the power button). The only way to turn on mac was to the unplug battery, plug in magsafe charger and then it would turn itself on. **After turning on, I could run the computer on just the battery so it is not that.
Finally replaced the keyboard and to my dismay power button is still not working AND the "i" key and shift key not working. (I am crying inside)
I tried SMC reset, but since the left hand side shift not working, tried right hand shift, nothing. Tried smc reset by unplugging battery and holding power button for 10 sec, didn't work. Annd to double check it is not the logic board I shorted the power pads and it started up.
So if there is a GOD please, please help me find a solution. I cannot keep unplugging and plugging in my battery and hating my life. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There is a lot of things sorted out on it so I would replace all the bad arts that are having issues and see if you have it back to new!
If you have any question's or concerns please comment below! Thank you
这个答案有帮助吗?
得分 0
1条评论:
I'm trying to figure out what the bad parts are. Any suggestions? Don't want to do each piece and turn around and find out I need a whole new logic board and end up paying double to find that out.
完成的
添加一条评论
添加你的答案
Mirdrewlo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 55
