跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Home button and wifi problems after changing my screen
Hello everyone,
I have changed a bricked screen of an iphone 6, (i changed some more screens and i have no problems) and when i turned it on, the home button is not working, the Touch ID is OK. And i can't enable wifi. When i try to enter settings, it freezze for some seconds and then crash. I need to make about 8-10 attemps to enter in Settings.
Some tests that i made:
1) I put all the new screen with the bad home button in another iPhone 6 and it works!!!
2) I put back the home button,the front camera, etc. in the broken screen(original) and it doesn't work.
3) I put another wifi Antenna, and i can't enable anyway.
Please, i don't know what is bad with the iPhone, can anyone help me?
Tks buddies!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Most likely you have to remove and reball / replace the Wifi IC. Heating it (Reflow) will most likely not work as there is underfill on the IC and heating it will cause the solder joints to expand and create more issues by bridging them.
You should google a reputable repair shop that does this type of repair locally if you can find one or use a mail in service. You can find several here on Ifixit business pros that will offer a reputable repair and most have a no fix / no charge policy.
There are also other components surrounding the Wifi IC that could cause the greyed out Wifi (Bluetooth spins but no connect). Without Microsoldering experience or tools of the trade will most likely cause further damage.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I'm guessing this phone was obtained second hand from someone?
Sounds like an issue caused by liquid damage from previous owner.
Wi-Fi issue can also be caused by liquid damage on the board. It's hard to tell but maybe someone here can help you with the board level issues which require micro soldering to fix.
这个答案有帮助吗?
得分 1
1条评论:
Thanks fow your answer. Is something unusual i know. My nephew is the iphone owner. I will ask him if he had a problem before.
I hope someone can help me here. We have a a good challenge to resolve.
完成的
添加一条评论
I guess it fell on the ground (screen crack), this could also be the reason.
Look at the homebuton connector if it is damaged or corrupted.
You could carefully try to heat up the wifi chip, but that is one of the last solutions to try.
Good luck!
这个答案有帮助吗?
得分 0
2条评论:
But the same homebuton in other iphone, works!
I changed the wifi antenna and it neither doesn't work.
完成的
I meant the connector on the logicboard
完成的
添加一条评论
添加你的答案
Martin Paturlanne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 999
