跳转到主内容
加入维修社区 - 创建账户
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
I can't connect to the internet using my mobile data, icon won't displ
I cannot connect my ZTE Z970 to the internet using mobile data. I have pulled down the notification panel and enabled the mobile data but the icon won't show . I have switched ON mobile data still the icon won't show up on the notification panel. I am unable to use my mobile data please what is the solution .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
已选择的解决方案
First thing to do is reset your phone to reset the network. You can also just switch airplane mode on and off.
If you already know that the settings are set, one thing I can advise is to turn on Data Roaming w/ Mobile Data on. I have no idea why this works, but I see this with certain androids. In order to have Data activated both options must be active.
If it's not working as a result of water damage/drop then please provide more details as to what happened prior to it not working.
If all fails, go see your carrier and see why you have no data.
这个答案有帮助吗?
得分 1
2条评论:
I tried all your suggestions and still the mobile data icon won't display nor activate. Prior to this issue I had done a factory reset because the soft keys (Home, Back and Options) were no longer working. It was after this that I noticed the data activation issue. I also have approached my carrier, and their suggestion also did not solve the challenge.
完成的
This may be a long shot, but I forgot to add this.
Check your Data Usage and see if there is a Cap on the data usage. You should be able to reset it and or remove the cap. After that restart the phone.
It's a rare one, but it does happen.
完成的
添加一条评论
最有帮助的答案
Hello everyone,I know this is an old thread but I still wanna share my idea about how to solve the ZTE Z970 no data connection ,to make a long story short just go to the apn settings in the phone add your carriers apn then head down to were it has IPV6 on still on the apn configuration menus were you added the apn and change it from IPV6 to IPV4 save your settings and make sure to tick the apn so activate it and there you go I tried I on several units and it works perfect
这个答案有帮助吗?
得分 5
6条评论:
thank you so much. I spent almost an hour with cricket trying to fix my phone after words they told me call zte. The guy helped me set up a new apn but left me stranded. I saw this and added this change to the new apn and it worked. thank you so much.
完成的
What and where is an settings? I hate when people use abbreviations
完成的
I'm having the same data issue
完成的
thank you I did spend about four days went to claro and tree repair shops and nothing did help did this changed from IVP6 to IVP4 and it worked . thank you again!!!!
完成的
thanks dear it help me too much
完成的
显示更多的1条评论
添加一条评论
I did the ipv change and managed to get 2G internet but it's too slow
这个答案有帮助吗?
得分 0
1条评论:
Same here,I have tried everything I could
完成的
添加一条评论
Is your sim card a 3g or 4g sim card?
这个答案有帮助吗?
得分 0
添加一条评论
What and where is an setting? When answering tech questions, don't use abbreviations. Also, an answer thread isn't food. It can't be “old". Corporations won't provide many answers and these thread answers STILL help,
这个答案有帮助吗?
得分 -1
2条评论:
Please I can not get the 3g or 4g network is still 2g and not making the phone to access the internet
完成的
Bro in the phone menu you have it written in abbreviation,Like APN ,IPV6 or IPV4 this 're technical terms and i expect you to know them as a tech
完成的
添加一条评论
添加你的答案
Ukan Anobo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 28
总计 12,824
