跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Battery Replacement not Charging?
I replaced my battery yesterday using iFixIt's kit. The phone powered on at around 68%. The calibration said to drain it to 10% and then give it a full unimpeded charge. So to my delight that took basically all night until the next morning. I was thrilled with the battery lasting so long.
Then I went to charge it and sure enough it wasn't charging. I had to get to work and by time I got into work the phone had died. When I plug it in to charge the phone recognizes a cord is there, because the battery signal turns on. It does not have the lightning signal below it, but rather the one red bar. Typically this would mean that it IS charging, and then would turn on. However, it just stays stuck on that red bar and does not turn on.
I should note that I had zero charging problems before doing the replacement. I took the time to clean out the connectors and everything in case that was the issue. I've tried multiple lightning cables, and plugging directly into USB.
I have searched the help for this exact issue and have found a lot of responses about a bad battery being dead on arrival. But none around what seems to have been a good battery but isn't charging.
Summary:
  • iPhone 6 not charging after replacing battery using iFixit kit
  • Replacement battery worked and was at 70% before draining to 0% the next day
  • Recognizes cord but stuck at charging screen
  • Cleaned charging port
  • Used different cables/power sources
  • No charging issues before
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
Hey Bryan! I'm having a member of our awesome CS team send you an email about this issue. In the meantime, I would say re-install the original battery if it's not too mangled from disassembly, and otherwise you might be sans phone until your new one arrives. :(
As a side note, well done taking care of your battery, I hope the replacement treats you better than this battery.
这个答案有帮助吗?
得分 0
1条评论:
Hi Alex. Thanks for the quick feedback! Unfortunately the old battery is a bit mangled. Not too bad, but not to the point where I'd be comfortable placing it back in (don't want it exploding or anything). Do you know if by chance the rep could rush a new battery? Would really suck to be without a phone for a week or so.
完成的
添加一条评论
添加你的答案
Bryan Rizzo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 1,391
