跳转到主内容
Repair guides for Gear Fit2, Samsung's fitness-oriented smartwatch, released June 2016.
50 个问题 查看全部
Gear Fit 2 no turning on...again
My gear fit 2 will not turn on. It does not show as charging either. I put it on the charger last night with 20% charge remaining and this morning it will not turn on or show as charging. I had the same problem a month ago and it was sent to Samsung repair centre in Toronto. It was returned working and fixed under warranty. Now I am in Florida and it does not work less than a week later. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Hold Down the power button while placing it on the charger. Hold for 30 seconds and let go. charging light should stay on..
-Warner
这个答案有帮助吗?
得分 0
添加一条评论
I tried it, then the screen appeared all white. I hit the button again and the lightning bolt comes out at 1% then it goes back to a full white screen.
这个答案有帮助吗?
得分 0
添加一条评论
In my watch charging symbol is showing and turning off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Don Newton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 2,103
