跳转到主内容
加入维修社区 - 创建账户
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Issues with Home and Power Button
I replaced the glass digitizer. In the process accidentally ripped off the Wifi/Bluetooth antenna. I replaced that and the glass but for some reason when I reassembled everything, the home and power button are not functional (only to turn on but not to wake or sleep). The volume and mute button still work fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
when you ripped of the antenna are you sure you didnt rip anything else off
完成的
From what I can tell, no nothing else looks out of sorts. Would you like pictures to make sure I'm not over looking anything?
完成的
添加一条评论
2个答案
最有帮助的答案
if the volume buttons work but the power button does not you have likely torn through the cable on the top right hand corner of the iPad when letting the digitiser, it can be replaced following this guide..
这个答案有帮助吗?
得分 1
1条评论:
The home button is not working either. Do you think I may have messed up something there as well? This is my first time attempting to repair an iPad. My apologies.
完成的
添加一条评论
You can also turn off the lock/unlock feature by going to Settings - Display & Brightness - Then turn off Lock/Unlock. This should allow your sleep/wake button to work again.
If you want to actually fix that feature, you will need to replace the power/volume flex as rayeasom mentioned.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jacob.v4 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 130
