跳转到主内容
Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
How to remove f(x) always showing it
in my calculator i cant find any answers because it is always showing f(x) in it
Update (10/17/2017)
in my calculator i cant find any answers because it is always showing f(x) in the screen.how can i remove it?please give an appropriate solution for this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Press Mode at right upper side and then press 1 for COMP. Thank You!!
这个答案有帮助吗?
得分 5
5条评论:
worked amazingly ,thanks so much!
完成的
thanks a lot !!!
完成的
Would this work for a Casio Fx-85GT X ClassWiz? I don't have a MODE button? :(
完成的
Thank you very much, it works.
完成的
very effective. thank you!
完成的
添加一条评论
I'd try resetting it. Removing the battery and putting it back should do this: Casio MH-10M Battery Replacement
Hope this helps!
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
anjanakrishna 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 99
总计 10,184
