跳转到主内容
Schwinn Mens Tourist 28"/700c Road Bike
8 个问题 查看全部
Why does my bike randomly not work (when peddling wont go)
Awhile back my bike, when peddling would randomly become loose for lack of a better term. At the moment whenever stopping it would act as if the chain fell off but upon inspection the chain and gears are fine, whenever this would happen i would continue peddling till it "locked in" which i've been calling it. When this issue happend i looked at the gears and chain on the bike to find the problem but everything was moving fine, so i believe it has to do something with the back wheel and the rear gears.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Nate, I've had this kind of issue before and usually what was happening is that my shifter indicated it was set to a specific gear, but the derailleur hadn't shifted all the way and would get caught in between gears. Not literally speaking, but it would cause issues similar to yours. I'd recommend if you have finger/thumb shifters to make sure when you shift that you push the levers all the way down so that you and your derailleur are on the same page.
I hope this helps.
这个答案有帮助吗?
得分 0
1条评论:
I'll test this out hopefully it will fix it, also whenever this would happen i would attempt to switch gears but it wouldn't fix it so that may also help diagnose the issue.
完成的
添加一条评论
添加你的答案
Nate Terrazas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 164
