跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
SSD Socket in HDD Model
I recently purchased a 21.5" 2015 4K Retina iMac from an old friend. It only came equipped with the standard 1 TB HDD but I'd like to replace it for a SSD. I'm wondering if I will find that there is still the Apple Socket for the OEM SSD's on the back of the logic board, so that I could add one of those (if I can find one) instead of adding a 2.5" SATA SSD?
Short question - is the SSD socket on the back of the logic board still present (just empty) on an iMac that only came with a spinning hard drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your systems specs: iMac 21.5" i5" 1.6 GHz (Late 2015) as well as the others in iMac 21.5" 2015 (iMac16,2) line.
From EveryMac:
  • This model has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive. If configured with a "Fusion" Drive or an SSD at the initial time of system purchase, it also has a PCIe connector (PCIe 2.0 x4 NVMexpress interface), but this connector is not present if the system only is configured with a hard drive at the time of purchase.
So sadly no, you'll need to swap out the 2.5" HD for a SSD or what I would recommend is think about getting a ThunderBolt2 external SSD RAID drive and make that your boot drive.
这个答案有帮助吗?
得分 0
1条评论:
Many thanks for the answer! Not what I was hoping - but SATA will work!
完成的
添加一条评论
添加你的答案
gregory 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 217
