跳转到主内容
AirDrop isn't working in 10.13.x
Since upgrading to High Sierra, AirDrop hasn't worked from my iPhone 5s to my MacBook Pro 13" Mid 2012.
Does anyone know how to solve this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
4条评论
Did you also update the phones iOS?
完成的
Are you using 10.13.0 or 10.13.1?
Also, are you using iOS 11.0.3?
完成的
I was up to date on both devices but still no joy
完成的
My iPhone 7+ will not transfer photos to my MacBook Air. The ios version on the phone is 10.13.1. The ios on the Mac is 10.13.1. What do I need to do?
完成的
添加一条评论
7个答案
最有帮助的答案
Did you review this Apple T/N? Use AirDrop to send content from your Mac. Can you explain what part of the process if failing.
这个答案有帮助吗?
得分 2
1条评论:
I am trying to send the photos from the iPhone to the Mac. The iPhone does not let me. The Mac lets me send them to the iPhone, but it won't receive them.
完成的
添加一条评论
Really a great post. I have read this marvelous post. Thanks for sharing information about fix Airdrop not working Mac Sierra on MacOS. I really like that. Thanks so lot for your convene. Visit this web page: https://www.howtoisolve.com/airdrop-not-...
这个答案有帮助吗?
得分 2
添加一条评论
AirDrop doesnt work on High Sierra
这个答案有帮助吗?
得分 2
添加一条评论
Im having the same issue, MacBook (13-inch, Late 2009) MacOs High Sierra version 10.13.6 (17G11023) update disabled the hyperlink to airdrop. How do I reactivate the hyperlink?
这个答案有帮助吗?
得分 2
2条评论:
Same issue here on same MacOS
完成的
Same issue here, same OS.
完成的
添加一条评论
same issue with my mac i dont get any options of letting anyone send me any files via airdrop. I am tired searching for a solution for the same.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same issue. I’ve changes networks, upgraded, restarted, nothing helps, especially not apple. this is why we should usb ports in iPhones and iPads. I should switch.
这个答案有帮助吗?
得分 1
添加一条评论
I think this article will help you with your problem - Fix: AirDrop Not Working on iPhone 13, 13 Mini, 13 Pro & 13 Pro Max.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
P J 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 50
总计 28,997
