AirDrop isn't working in 10.13.x
Since upgrading to High Sierra, AirDrop hasn't worked from my iPhone 5s to my MacBook Pro 13" Mid 2012.
Does anyone know how to solve this issue?
Did you review this Apple T/N? Use AirDrop to send content from your Mac. Can you explain what part of the process if failing.
这个答案有帮助吗?
I am trying to send the photos from the iPhone to the Mac. The iPhone does not let me. The Mac lets me send them to the iPhone, but it won't receive them.
Really a great post. I have read this marvelous post. Thanks for sharing information about fix Airdrop not working Mac Sierra on MacOS. I really like that. Thanks so lot for your convene. Visit this web page: https://www.howtoisolve.com/airdrop-not-...
这个答案有帮助吗?
Im having the same issue, MacBook (13-inch, Late 2009) MacOs High Sierra version 10.13.6 (17G11023) update disabled the hyperlink to airdrop. How do I reactivate the hyperlink?
这个答案有帮助吗?
Same issue here on same MacOS
Same issue here, same OS.
same issue with my mac i dont get any options of letting anyone send me any files via airdrop. I am tired searching for a solution for the same.
这个答案有帮助吗?
I have the same issue. I’ve changes networks, upgraded, restarted, nothing helps, especially not apple. this is why we should usb ports in iPhones and iPads. I should switch.
这个答案有帮助吗?
I think this article will help you with your problem - Fix: AirDrop Not Working on iPhone 13, 13 Mini, 13 Pro & 13 Pro Max.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 52
总计 28,999
4条评论
Did you also update the phones iOS?
由 Dan 完成的
Are you using 10.13.0 or 10.13.1?
Also, are you using iOS 11.0.3?
由 S W 完成的
I was up to date on both devices but still no joy
由 P J 完成的
My iPhone 7+ will not transfer photos to my MacBook Air. The ios version on the phone is 10.13.1. The ios on the Mac is 10.13.1. What do I need to do?
由 elainefarrar 完成的
